Frame generator cut list - angle of cutting
I'm having trouble quoting the cutting angle of a frame member, such as a square tube or I-profile....
Suppose a cut at 60°:
If I represent the piece on the drawing, I have the possibility of quoting the angle of the extremity, ie 60°, or its supplementary ie 130°.
The value of the "CUTDETAIL1" property suggests 60°.
BUT AT THE MACHINE TOOL, THE ANGLE THAT THE OPERATOR MUST SET ON THE SAW IS THE COMPLEMENTARY 30°!!
First of all, I'm looking for a dimensioning method that doesn't waste too much time on each single end.
It could also be okay to edit the additional dimension 130°-90° so as to obtain a 60°..... but keeping the 130° parametric part so as to be able to absorb any small changes in a second phase.
Secondly, one could think of a "cut list" table where only the angles needed to set the machine to the desired cut are highlighted.
Thanks for your help.
