Frame Generator could not be created?
Message 1 of 14
Just want to ask what does the error means? Suddenly got the error after applying frame generator.
I did found similar error discussion http://forums.autodesk.com/t5/inventor-general-discussion/frame-generator-not-inserting-part/td-p/37...
But, was not solved.
Admin if this is not appropriate please delete.
Replies (13)
Message 2 of 14
I tried the DIN and manage to apply. BUT, I could not save the assembly file.
Message 3 of 14
blair
Are the required CC libraries in your Project File? Just because they are installed doesn't mean you have access to them.
http://autode.sk/1IWjry3
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 4 of 14
Hi Blair,
Would you mined elaborating further.
Is these want you meant? Do I have to add in the CC Libries to the projects Libraries
Message 5 of 14
blair
Did you click on the link in my post, it will bring up a video showing what needs to be done. Most likely you don't have any CC's added to your Project File.
Delta Tau Chi ΔΤΧ
Message 6 of 14
Hi Blair,
I have configure libraries.
That is why I have also attach the libraries folder
Yes I did play the video
Message 7 of 14
WHolzwarth
Hmm. Perhaps I'm right, perhaps I'm wrong.
The above path to your file location is very long. Could you try with another location?
Walter
Walter Holzwarth
Message 8 of 14
Mark.Lancaster
Yeah I would have to agree with WH about the long path name...  But I could be wrong too..  Smiley LOL
Mark Lancaster
Message 9 of 14
blair
The path shown, is the default install path and locations for a stand alone install of Inventor. Nothing wrong with the length, look carefully at your Project File. Make sure that all required Libraries as well as all the locations that you are stored files are in the Project File path.
Possibly the "Save Error" is the folder that these parts reside in, or want to be placed in are a Library folder. Check your Project File to see that this folder is not a Library folder, if so, then change it to a Read/Write as all Library Folders by default are Read-Only.
Delta Tau Chi ΔΤΧ
Message 10 of 14
Mark.Lancaster
Blair
We were talking about the location where the actual frame generator model is located.  Not any of the installation path/location.
Mark Lancaster
Message 11 of 14
blair
The O/S limit is 254 characters but that doesn't mean that Inventor still has some old pre Vista code for path length.
Delta Tau Chi ΔΤΧ
Message 12 of 14
Hi Blair,
Here is the screen shoot of the Project dialog box. Ever since I am using a Rad/Write Style Libraries.
Message 13 of 14
blair
Your "Styles" Library is set to Read/Write but all the items that are in your Library folders are read only unless they are set to Read/Write. These are two completely different items.
The "Styles" Library control items such as your Dimension Styles. The low item that you have high-lighted will be read only. These are places to store IPT and IAM files that you will need for your work but don't want any changes to be made to them.
Delta Tau Chi ΔΤΧ
Message 14 of 14
These frustrates me already. I am NOT able to make use of the Frame Generator. It was working properly before I make changes on 1 of the frame member. Did tried doing this and doing that BUT still...
