Frame Generator Aluminum Angles
jcharronYJF55
jcharronYJF55
I notice that pretty much all my options in the tool are for structural steel, hot rolled steel, angle steel, hot rolled structural steel, etc.
Which is the correct option for aluminum angles? Is it even available in the tool?
CCarreiras
Hi!
frame generator uses standard profiles from the content center.
If the profiles you use doesnt exist in the content center, you can create, Authoring and add your profiles to the content center, and then you are able to use them with Frame Generator.
Tip: to author custom profiles, instead of creating and authoring a profile from the scratch,  is easier to copy one similar form the content center, edit as you need and then authoring and add it to CC.
CCarreiras
jcharronYJF55
thanks where is a tutorial to start me doing that?
CCarreiras
jcharronYJF55
