I have old version file of frame generator link to exel.
I can try to change value on v.2018 any condition is ok.
When I try to change value ion V.2019, That have a problems.
Can somebody suggest me, please?
Solved by johnsonshiue. Go to Solution.
Hello ballnr,
The issue you are having is that frame members are incorrect location from skelton, right?
If so, it seems to work well after Rebuild All.
Hi! Could you describe the exact steps leading to the failure? I am not seeing the problem either. I edit the Excel spreadsheet and change Height to 13000 and it updates accordingly on return.
Many thanks!
Thank you for your support.
May be have a problems which my computer only.
I try in other computer is fine.
