Announcements
Frame Gen Square Tubes
ferrisb
ferrisb
Inv 2022.
I'm working on a frame & we are using square tube aluminum extrusions that are 2x2x1/8.
What we use has square (sharp) corners, not corners with fillets.
Is there a standard I can select that matches this, or could anyone else share what they would/have done?
-Thanks
BDCollett
If one does not exist then you can create your own, take an existing one and modify it would be easiest.
ferrisb
I'm not sure that I follow...
Are you suggesting that I edit the feature for each frame member, or are you saying I can take an existing content center profile & modify it, possibly here.
BDCollett
This video covers what I mean I believe.
You can create your own library and customize it to suit.
In your image you have had some previously as shown in red at the top. You may need to find those and move them to the same folder in order to use them again.
Creating Frame Genrator Profiles in Autodesk Inventor - YouTube
ferrisb
Thanks for the video BD, I'll give it a shot.
gcoombridge
Speaking from experience, one thing to be cautious of is modifying a frame generator library to have a zero radius on its profile. I did it with an angle profile and as a consequence it wouldn't notch. It wasted a lot of hours trying to work out what the issue was!
I would take @BDCollett's  advice and build your own
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
kent_wold
I also have had this issue and after many years of begging Autodesk to add a square profile tube for Aluminum it still hasn't happened.
Adding your own library of custom stock tubes is the way to go and reducing the corner to a minimal radius is the correct way to do so.
One benefit is learning how to add a custom library and you can use your own company's part number designations for those parts saving you time in Part lists etc.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
