Frame gen not updating with sketch dimension change
Benjaaamin
Benjaaamin
Hi All,
Encountered a problem with frame members not updating after changing dimensions within a master sketch. This seems to be an issue that happened early 2024, reading through the forums. Have run 'rebuild all' on the assembly, the frame and all the way down to the parts. See attached image where members are not aligned with centroids or heels of members.
Pack and go attached.
CCarreiras
Hi!
It's updating...
(view in My Videos)
Can you specify better the issue?
CCarreiras
kacper.suchomski
It works for me too. We need more details about your problems.
A small suggestion - cutouts in profiles should be done at the part level, not the assembly level - in the current version you will not see this machining on the part drawings.
Kacper Suchomski
Benjaaamin
Hi all,
After checking everything in and closing Inventor then re-opening everything the issue seem to have cleared itself!
There must have been a temporary bug along the way because I would change dimensions and plane positions and nothing would update, even after a full rebuild.
Seem to have been an IT Crowd 'Have you tried turning it off and turning it on again?' 🙄
Thanks for your follow ups!
