So I am sure this is probably an easy thing to do but this is my first venture into forming sheet metal when the overall width and length is set my purchased sheet metal blanks. Basically I will be forming multiple bends into a sheet metal blank (bend origins will be based of the centerline of the material and not the edges). The flange lengths are set and the final flange lengths will just be the remainder material. this will eventually be used to produce a template where we can just enter certain perameters and it updates the bend line locations. In my attempts to use bend command I can get it close but not exact (we have tolerances of .001).
best example I can give is forming a channel where the outside to outside dimension of the legs is a set distance and the leg lengths will just be whatever is left over of the material.
