Hello every-body,
I just found a possible error in "Molle a compressione: formule di calcolo per le unità metriche": in the legendas under the formulas, almost every time the variable F1 and the variable F8 are displayed, the suggested unit is MPa instead of N. I would suggest a check.
Regards
@Anonymous I checked with our simulation expert and he agrees that it should be updated.
Not sure if you already submitted something, but in the future if you find other discrepancies you can report your findings at the Was this helpful? near the bottom of the page:
Thanks for the heads up!
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
