Inventor Forum
Font changes when printing
12 REPLIES 12
Message 1 of 13
1825 Views, 12 Replies
I have searched this forum and others for the past few hours with no luck.
Inventor 2018, latest update, fresh install from scratch (SSD died and was unrecoverable)
Previously, whenever I would print, the result from the drawing to the page was WYSIWYG. All fonts and sizes matched, and were scaled appropriately.
Since the new install, anytime I go to print preview, the drawing is changing the letter spacing and font size to be unreadable, and definitely not scaled with the rest of the drawing.
I have looked through every setting in Windows and Inventor that I could find, and no luck there. I have attached screenshots of the before and after, as well as a copy of the .idw file.
12 REPLIES 12
Message 2 of 13
johnsonshiue
Hi! Sorry for my poor memory, I could be wrong. I do recall seeing an issue like this. But, I remember it was already fixed in one of the 2018 updates. If possible, please install 2018.3 update followed by 2018.3.6 update.
Many thanks!
Software Test Engineer
Message 3 of 13
in reply to: johnsonshiue
That was it, thank you very much for the reply.
Message 4 of 13
I get this exact problem in 2020, is there a solution?
Message 5 of 13
Desmo1275
Myself and other users are currently experiencing this issue in Inventor Professional 2019.  Is anyone aware of a fix for this in 2019?  Printing from Inventor or Vault will show the font changes.  Saving out to AutoCAD is fine.  Any help is appreciated.
Message 6 of 13
johnsonshiue
in reply to: Desmo1275
Hi! It should work on 2018 and later. You might be seeing a different issue. It might be the same as INVGEN-28721, which has been fixed on the coming 2020.2 update. Once the update becomes available, please try it out.
Many thanks!
Message 7 of 13
Desmo1275
Will the 2020 update fix a issue on 2019?  When is this update scheduled to be posted?
Message 8 of 13
johnsonshiue
Hi Guys,
I think I may have misunderstood the issue. I need to check with the project team and see where we are at. I will report the findings.
Many thanks!
Message 9 of 13
rui_wang
Hello jhutchesonV8UT2,
This is Rui from Autodesk Inventor team. Thanks for your posting.
As it cannot be reproduced on my machines, did you still reproduce this issue? If yes, could you please let me know below information,
  • OS Version
  • OS region
  • If possible, could you please help to record the recreated steps?
Here is my email, rui.wang@autodesk.com. Please reach me if you have any more information about this. Thanks a lot.
-Rui
Message 10 of 13
rui_wang
Hello cestill,
Could you please help to attach some captures and drawing files for reproducing this issue? And please attached below information as well,
  • OS Version
  • OS region
-Rui
Message 11 of 13
rui_wang
Hello Desmo1275,
  • OS Version
  • OS region
-Rui
Message 12 of 13
johan.monnier
Same problem with Inventor 2022.
I had to use the "Inventor Reset Utility" to solve the issue (don't forget to save options and customisation before).
Edit : The problem come back one hour later...
Message 13 of 13
Hi Johan,
I am not aware of the issue. Based on the behaviors you described, it seems that resetting the Inventor settings back to install default helps. However, the setting does not seem to stick. This sounds like a user profile issue. Try running Inventor as Admin (right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as Admin."
Many thanks!
