Inventor Forum
flatten a solid
4 REPLIES 4
987 Views, 4 Replies
flatten a solid
Hello Gentlemen,
I have a problem.
I'm tying to flatten out some curved solids (to make drawings for laser cutting and for measure sizes), but no success.
If it's just a simple curve, like a half pipe, it works. If it has more faces, just the one I made just for testing (on attached pic), no success.
Could you please help me to do this?
Thank you in advance!
4 REPLIES 4
CCarreiras
Hi!
1 use the same thickness in the solid and in the rule
2 Always fully constrain the sklecth
3 if you are working in sheet metal, and you want flat patterns, use the sheet metal tools.
4 Do the tutorials or get some training... you have to know more about Inventor.
Check the part, Check the sketch and the Flange tool:
CCarreiras
in reply to: CCarreiras
Hello Carlos,
thank you for the help.
I know I have to learn more about inventor. This is why I ask questions.
I could flatten the sample part with your picture guide. Then I tried to flatten a real part.
This line was created by cutting a solid, so it is made from splines - I cannot measure radius for them.
The sketch is fully constrained, but I cannot make sheet metal from it. I can make a surface from is (extrude), so theoretically the curve is OK.
Do you know and would share with me why?
Thank you!
CCarreiras
Hi!
The question is: you can not have sharp edges, all have to be tangent, or the spline must be continous.
I made a continuos spline, check if it fits you, if it's under the tolerance... i guess it is...
CCarreiras
Thank you Carlos, you made my day.
Autodesk Customer Advisory Groups
