Flat Patterns Dashed Lines
chrisw01a
chrisw01a
Why does it do this?
This has happend many times over the years, but with 2017 pro, it seems like any new flat pattern I create does this when placed on a drawing.  I have to go back into the flat pattern and redefine the alignment, and then it shows up ok after that.
Anyone else have this?  This is so very annoying.
Attached are some images and the parts.
Thank you!
jeanchile
I have been having this exact same problem lately. I have to open the part, go to the flat pattern, go back to the folded part, save it, close it, then go back to the drawing view, make it raster, then make it precise, then it works. A bit of a PITA.
Inventor Professional
chrisw01a
Good to know it's not just me! Does anyone have a solution to this?
Curtis_Waguespack
Hi chrisw01a,
Here is a related link:
http://forums.autodesk.com/t5/inventor-general-discussion/sheet-metal-flat-patterns-appear-as-dashed...
I hope this helps.
Curtis
chrisw01a
Thanks.  Seems like a bug.
Curtis_Waguespack
@chrisw01a,
Did you try this suggestion by chance?
Originally posted here
@Anonymous wrote:
Next Time, try this : Go to your sheet metal part > Select the Flat Pattern or the Folded Model, goto Manager > Update > Rebuild All.
Look at your drawing Smiley Very Happy
Fred Bellekom
Inventor Pro 2016 / Vault Pro 2016
I just ran into this issue, and tried the rebuild all and it resolve it for me in Inventor 2017, I was curious if that resolves in 2018 also.
I hope this helps.
Curtis
chrisw01a
I did actually. It seems to work for me. Thanks
