Flat pattern with a rectangle that rotates | / - \ - / | ....
FilipeMais
Message 1 of 12
FilipeMais
https://drive.google.com/drive/folders/1x5hRR5z5_4Kz2ReUc9Tm7HF2ztKwVDcj?usp=sharing Dear all,
I'm using Inventor 2022 and I need to draw  a pattern with around 50 rectangles with different angles. In the end, it should be mirrored to the right.
I drawn like what you can see bellow.
Are the better solutions?
Thanks in advance 😉
Full plateFull plateDetailDetail
Accepted solutions (3)
Replies (11)
Message 2 of 12
JDMather
@FilipeMais
Can you Attach your *.ipt file here?
Pattern Features rather than sketch elements.
In any case i would not duplicate sketch dimensions (have you used Sketch Blocks).
Do you have a picture of something similar that already exists in the real world?
Message 3 of 12
BeKirra
Yes, agree with JDMather.
Using rectangle sketch block could be a better solution in your case.
Then mirror the solid features as you have already mentioned.
Note: the specific feature "pattern" function is not available in Inventor if you are looking for it.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 4 of 12
IgorMir
Hi Filipe,
Technically - it is not a pattern. It is a set of individual cuts. Because of their orientation. What you are asking for is to array a set of similar cuts but to rotate every occurrence of them on a specific angle. I afraid - you are out of luck here.
The part still can be modeled. It just takes a bit of a time. But not a huge amount of it, really. Here is a part in IV2020 format.
Cheers,
Igor.
Web: www.meqc.com.au
Message 5 of 12
r.burggraaff
Olá JDMather,
Thanks for your reply.
I updated the post and inserted the link to get the part.
The part already exists in the real world, but there isn't a drawing and I don't have photos of it.
Thank you
Message 6 of 12
cidhelp
Hi @FilipeMais ,
with iLogic you can create such pattern:
Dim oLine As SketchLine = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchCurveLinearFilter, "Horizontale Skizzenlinie wählen:")
If oLine Is Nothing Then Exit Sub
Dim oSk As Sketch = oLine.Parent
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
If oLine.StartSketchPoint.Geometry.Y - oLine.EndSketchPoint.Geometry.Y > 0.001 Then
	MsgBox("Nur horizontale Linien möglich.")
	Exit Sub
Dim oSPt As Point2d
If oLine.StartSketchPoint.Geometry.X > oLine.EndSketchPoint.Geometry.X Then
	oSPt = oLine.StartSketchPoint.Geometry
Else
	oSPt = oLine.EndSketchPoint.Geometry
HL = InputBox("Abstand zum Mittelpunkt", "Skala_1", "1500")/10
'Dim AnzL As Integer = InputBox("Anzahl Skalenstriche", "Skala_1", "10")
AbL = InputBox("Abstand Skalenstriche", "Skala_1", "100") / 10
ReL = InputBox("Rechteck Länge", "Skala_1", "40") / 10
ReB = InputBox("Rechteck Breite", "Skala_1", "10") / 10
Dim Lg As Double = Abs(oLine.StartSketchPoint.Geometry.X - oLine.EndSketchPoint.Geometry.X)
Dim AnzL As Integer = Floor((Lg - AbL / 2)/AbL) + 1
'senkreche Hilfslinie
Dim oCPT As Point2d = oTG.CreatePoint2d(oSPt.X, oSPt.Y + HL)
Dim oSLine As SketchLine = oSk.SketchLines.AddByTwoPoints(oSPt, oCPT)
oSLine.Construction = True
Ab = AbL / 2
Dim oRPt As Point2d
Dim oColl As ObjectCollection
For i = 1 To AnzL
	oRPt = oTG.CreatePoint2d(oSPt.X-Ab , oSPt.Y)
	Wi = Atan2(HL, Ab)
	oSLine = oSk.SketchLines.AddByTwoPoints(oRPt, oCPT)
	oHPtL = oTG.CreatePoint2d(oRPt.X, oRPt.Y - ReL/2)
	oHPtB = oTG.CreatePoint2d(oRPt.X - ReB/2, oRPt.Y)
	oReLines = oSk.SketchLines.AddAsThreePointCenteredRectangle(oRPt, oHPtL, oHPtB)
	oColl = ThisApplication.TransientObjects.CreateObjectCollection
	For Each oSkEnt In oReLines
		oColl.Add(oSkEnt)
	Next
	oSk.RotateSketchObjects(oColl, oRPt, PI/2+Wi, False, True)
	Ab = Ab + AbL
Next
oLine.Construction = True
Message 7 of 12
JDMather
Why did you not Attach the *.ipt file here as requested?
Message 8 of 12
FilipeMais
Hi Igor,
Thanks for your reply. Even more, thank you for the file. ;.)
I thought it could exist an automatic way to do it.
Because yesterday I needed to make 50 holes, but next time could appear a model that needs more than that... :-S
Thank you.
Message 9 of 12
FilipeMais
Thank you, cidhelp,
In one word: Spectacular!
Thanks for sharing a different way to do the job.
It is a great incentive to learn how to use iLogic.
Thank you
Message 10 of 12
FilipeMais
Sorry... I am a beginner in the forum.
Just now i see it exist a way to share a file.
I guess it is ok now. 🙂
Message 11 of 12
IgorMir
Hi Filipe,
Yes, if you do it on a regular basis - iLogic is a great help, as had been already demonstrated by cidhelp.
Cheers,
Igor.
@FilipeMais wrote:
Hi Igor,
Thank you.
Message 12 of 12
JDMather
@FilipeMais
Where are you going with this design?
Do you have a picture of something similar from the real world in finished form?
I suspect that there might be a much easier technique if you are going where I think you are going with the final form design.
