Message 1 of 8
Having problems with a flat pattern being created properly. The part is a derived solid from another part. Both parts are ensured to have matching Sheet Metal Styles. The solid body was made using the contour flange command. Even with a document update and rebuild the flat pattern will still not flatten correctly.
The only way I've found to fix this is to manually delete the flat pattern, and then recreate it, but this isn't really an option for runtime when it needs to be done automatically. There is also a sketch, and an associated punch tool in the flat pattern which would be a hassle to setup in code to recreate every time.
Thanks for any help or guidance anyone can provide!
