Hello
I'm sure there is a solution somewhere but I haven't been able to find it.
I work in Inventor 2016.
I have a multibody ipt containing 122 solids. I derived those solids into parts where the parts were needed. Then I transformed some of those parts to sheet metal and created flat patterns so I can use them for my IDWs.
One of the said parts is a very simple handle made of a round bar of metal with two bends in it. In my multibody part I swept a profile around a path by using sweep and it gave me the folded model I needed. But for the life of me I have no idea how to make a flat pattern for that part.
Do bare in mind, I am aware that it isn't possible to flatten a sweep in sheet metal. That's not the issue. I'm just wondering how to model a round bar with two bends in order to get to have a flat pattern that can be placed in an IDW. I did look at a tutorial about achieving this via normal ipt bend part, iPart creation and feature suppression. Visually that helps. But it still does not produce a real flat pattern where I can point to the bend lines like with normal sheet metal parts.
Please do not ask me for a file :). The part itself is not important. I am just wondering how to make the flat pattern.
I also thought about using tubes and pipes, but I am actually not sure if it is possible to pick round bars. (as in, not hollow). I tried defining a path and a contour in sheet metal but the contour sweep tool does not pick up a closed contour.
I mean, yes, I do realize it is called SHEET metal and a round bar is not a sheet and all that, but still... HOW do you get a real flat pattern for a bent bar? It bugs me 😛
Many thanks for your help.
BR,
Kami
