How can I fix the resolution of the text in lists like the ones in morrior components in assemblys?
Here is photo
This looks like it could be an issue with a 4K monitor.
Give this a try, close Inventor, then find your Inventor shortcut & make a copy of it.
Right Click on the copy and go to Properties. Click onthe "Compatibility" tab, then "Change High DPI settings"
Try the different settings and see if this helps with your setup.
Hi! I vaguely remember there was a bug like this on 2020. Please make sure 2020.3 update is installed followed by 2020.3.3. If it still does not work, maybe you want to try Inventor Reset Utility (All Programs -> Autodesk -> Inventor 2020 -> Tools) to reset all settings back to install default.
Many thanks!
