'Find' command issue: selection of all the occurrences in model state.
gusi_cl
gusi_cl
As you can see in the attached video, this does not allow you to toggle the visibility of unsuppressed occurrences in the model state.
johnsonshiue
Hi! I don't believe the visibility of suppressed components (LOD or Model States) can be set. You need to unsuppress the components, change the visibility, and suppress them.
Many thanks!
Software Test Engineer
gusi_cl
Hi Johnson, your solution is only a workaround useful only for the simple example I've posted. If you have a complex assembly with several levels, became impossibile to unsuppress, opening and selecting the parts for every subassemblies, turn off visibiliy, and suppress again.
My opinion is that the 'Find' must exclude automatically from the selection suppresed parts that are obviously non visibles.
