Inventor Forum
Filling hollow objects
8 REPLIES 8
Message 1 of 9
1085 Views, 8 Replies
Hi guys.
I wondering if anyone would be able to help me with filling in a complex hollow object.
I've tried patch up the surfaces and using the sculpt function, however this doesn't appear to have worked.
Thanks in advance.
8 REPLIES 8
Message 2 of 9
mdavis22569
Hi and welcome to the forum ....
Can you share the model file with us ?
Mike
Mike Davis
Message 3 of 9
in reply to: mdavis22569
Hi mike,
Let me know if you can see the attachment.
Ali
Message 4 of 9
TheCADWhisperer
Did you attach the correct file?
The geometry in the file that you attached is completely solid.
Message 5 of 9
in reply to: TheCADWhisperer
How do i know if the object is solid? I checked its physical properties after i tried editing it and the mass remained the same.
Message 6 of 9
mdavis22569
It's solid, you can half view and see inside
Mike Davis
Message 7 of 9
TheCADWhisperer
@Anonymous wrote:
..I checked its physical properties after i tried editing it and the mass remained the same.
Attach the edited file here.
Did you Update?
Message 8 of 9
mcgyvr
Tools...application options.. general tab.. check the box for "Update Physical Properties on Save"
Message 9 of 9
mdavis22569
I updated the material type ...and it's updating for me
Mike Davis
