fillets
fillets
Message 1 of 10
fillets
might sound simple but how do i make a fillet?  i have to parts,a rod and a flange that i made into an assembly.  i now made a new part by deriving that assembly.  the derived part will be the drawing of those two parts "friction welded" together.  after being friction welded there will be what looks a weld.  it's actually not weld since now the two parts have become one solid part.  the metal that "oozed" out will have to be machined off.  i have made a revolve cut to remove some material on the rod now i need to add a fillet between the "two parts" that are now one.
im sure it's simple i just dont know how to do it.
Replies (9)
Message 2 of 10
tech
Can you share your parts and assy?
Message 3 of 10
Cadmanto
If you are looking to make a fillet weld, you will need to convert your assembly into a weldment.
https://www.instructables.com/id/Introduction-to-Weldments-in-Autodesk-Inventor/
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 4 of 10
swalton
The fillet command should be in your 3d modeling toolbar.
https://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-590A8760-FFBB-41C8-8169-6B7002207884
Steve Walton
Inventor 2025
Vault Professional 2025
Message 5 of 10
I have converted many assemblies into weldments. What I don't know and never thought about until now, when you turn an assembly into a weldment does it consider, turn it into basically one part? I'll give it a try and see.
Message 6 of 10
Cadmanto
No, It is still an assembly regardless.
It just enables you to place actual fillet welds.
Inventor Pro 2020
Best Regards,
Scott McFadden
Message 7 of 10
I'm not welding, it's being friction welded...
Message 8 of 10
JDMather
Attach your derived part here (or a dummy that exhibits the same behavior) and end all doubt.
When you Derived - did you set it to single body?
Message 9 of 10
No, did not set anything to single body. Not sure how.
I did a "save as" and saved it to my desktop. Here it is
Message 10 of 10
i just logged back into the forum and saw your post here. i was responding and reading my emails.  i made another derived part and found the icon for "single part".  it worked!
THANKS!
