File Expansion Tab in Inventor 2022
BeKirra
Advisor Advisor
BeKirra
Notice the Home tab will be hidden when multiple files are opened.
I am wondering if an expansion tab available in 2022 as it is showed in early release.
Have look in "Options" but don't find a setting for it.
Did I miss something?
Thanks.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
CCarreiras
Hi!
You can find home at the menu.... or use the arrows to find home
CCarreiras
BeKirra
Thanks. That is the one.
But it will be easily to expand all drawings showing in the same window when user accidentally keep press the "Scroll Right" arrow after it scrolls to the end.
In my opinion the new layout design is not as better as the previous version.
X² + Y² = C²
