FG PFC notch custom profile missing
aurel_e
aurel_e
Hi all
I am using Inventor 2020.
I was expecting to have the custom notch profile for PFC as it already exist for "I" profile beams.
Now I have already set all my frame elements but I don't want to notch them manually.
What would be the easiest way?
2020-02-19 16_36_09-SCI_P363-secure.pdf.png2020-02-19 16_34_35-Autodesk Inventor Professional 2020.png2020-02-19 16_31_31-Autodesk Inventor Professional 2020.png2020-02-19 16_30_21-Autodesk Inventor Professional 2020.png
Replies (7)
johnsonshiue
Hi! I am sorry if I misunderstood the issue. Did you publish the custom profile to Content Center? Is the particular standard included in the Content Center Library?
Try this simple workflow. Go to Content Center and try finding the Custom profile under Steel Shape. Is it there?
Many thanks!
Software Test Engineer
aurel_e
It is not a custom profile beam. It's a BS4 parallel flange channel.
I was talking about the custom notch. From 2020 you can customize the notch simply when you use the notch tool (you don't have to set the custom library etc.) I thought it was possible for all the beams, but I am discovering now it is not available for the PFC profile.
Roman_Vesely
Hi Aurel,
thank you for your feedback.
 in 2020 is available only "I" custom profile. We are working on other types. If you are interesting you can Sign In to our Beta forum https://feedback.autodesk.com/welcome/ to see more information & try new upcoming features there.
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
aurel_e
Hi
I appreciate all the replies.
Anyway I'm not sure this would be considered a solution.
The fact that Autodesk people  "are working" on it, means that there is not a solution yet.
johnsonshiue
Hi! I marked Roman's posting as a solution. The notch custom profile is a new feature currently available on Inventor Beta to test. Please feel free to try it. The new feature will not be available on current or prior releases.
Many thanks!
nathan_coleQ5ZMQ
Community Visitor
Community Visitor
Hi ,
just want to confirm if there is any solution to this problem yet.
pcrawley
Yep - it's been here a while.  Not sure exactly which release, but on reading some of the comments above, I guess it was around Inventor 2021.
This screenshot is Inventor 2024:
Peter
