FEMAP W/ NX Nastran Conversion into Inventor
Cadmanto
Cadmanto
I have a coworker that creates models using the above mentioned software.  I personally know nothing about its functionality.  What I do know is he exports out the assembly models as step files and it creates a single files for every part (meaning if the same part is used 12x, 12 different file named parts) and each is a dumb solid.
I end up recreating each part with features and smarts.
My question is if anyone knows if there is a setting within his software that would allow these models to export a little more cleanly.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
blair
You can look at the Feature Recognition Tool within the Inventor Apps store. This should help with some of the features. He should check his export settings. I get many models from venders and their models import fine with the reuse of the same parts.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
