Feature migrator 2021
mat_hijs
Message 1 of 8
mat_hijs
Does anyone know of a feature migrator that migrates assembly features to the affected parts that works on Inventor 2021? The one by coolorange works up until Inventor 2020, but they left a notice that they will not be updating this for Inventor 2021 and higher.
Replies (7)
Message 2 of 8
L.Greft
There's been a similar post you can find here ,the answer by @johnsonshiue should work (see also below).
Hi! There is a way to make it load on 2021. After the tool is installed, please go to the following folder and find "coolOrange.FeatureMigratorAddin.Inventor.addin"
C:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_featureMigrator.bundle\Contents\
Edit the file in Notepad and change the following value from 25 to 26. Save.
<SupportedSoftwareVersionLessThan>25..</SupportedSoftwareVersionLessThan>
After that, the add-in should load.
Check out my ideas: https://autode.sk/2TKe6LH
Message 3 of 8
mat_hijs
This worked, thanks a lot!
Message 4 of 8
francesco_rossato
Hello everyone,
how about the same question made by @mat_hijs but for Inventor 2022? Is there a similar way to do it?
Thank you,
Francesco
Message 5 of 8
mat_hijs
I haven't tested this since I try to stay away from assembly features as much as I can, but have you tried changing this value 1 step further? So, make it 27?
Message 6 of 8
WHolzwarth
Two changes are needed:
In C:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_featureMigrator.bundle\PackageContents.xml line 6:
<RuntimeRequirements OS="Win64" Platform="Inventor" SeriesMin="Ir21" SeriesMax="Ir27" />
In C:\ProgramData\Autodesk\ApplicationPlugins\coolOrange_featureMigrator.bundle\Contents\coolOrange.FeatureMigratorAddin.Inventor.addin line 12:
<SupportedSoftwareVersionLessThan>27..</SupportedSoftwareVersionLessThan>
I've set 27 to 28, because of upcoming next Inventor in 2022.
Walter Holzwarth
Message 7 of 8
francesco_rossato
Hello @mat_hijs and @wh,
thank you for your reply!! I'll try to do it asap 🙂
Francesco
Message 8 of 8
francesco_rossato
Hello @WHolzwarth,
just to confirm you that I tried to change the setting and it works!
Thank you again 🙂
