Hi Ali,
The behavior does not look right for sure. Could you attach the files here or send them to me directly (johnson.shiue@autodesk.com)?
Many thanks!
Hi Ali,
This is about silhouette projection in assembly sketch. This particular case does not seem to work in all releases I tried. The edges do not exist actually. I guess the wrong side was picked when they are projected to the sketch. Interestingly, it works fine in part sketch. I will work with project team to understand this behavior better and see what we can do.
Many thanks!
