Hoping someone has a 3D model or STEP file for a Fall-arrest system anchor post Model #8516691
Tried a few websites i know of, with no luck.
thanks
Solved by kelly.young. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
@Anonymous
Most likely you will have to end up modeling it yourself.. In addition because you are using such a legacy version of Inventor it will be hard to find data that even matches that 8yr old version.
Have you asked the vendor to supply you with dimensional data or a model? I always used the wording.. Well I need your model for a design I'm working on, If you can't share the information with me I guess I will find another vendor..
Sometime it works and other times it doesn't..
Mark Lancaster
& Autodesk Services MarketPlace Provider
Most likely, but worth asking the question.
Tried the vendor with no success.
STEP files .stp work just fine with my Inventor version
Do you have an existing anchor post to work from? Not sure of your aim but maybe look into Remake.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
It seems like you're looking for a specific model for a Fall-arrest system anchor post. While I don’t have a 3D model or STEP file for this particular model, you might want to check out platforms that specialize in construction and safety equipment design. If you're working in law enforcement or need relevant records, you can visit SC Crime Records for more information related to South Carolina's police records and arrest updates.
