Fade Function
Fade Function
Fade Function
Does anyone know if Autodesk has fixed the fade function in the Inventor Studio? Right now I have it fade out at 0 seconds but when I go to render the image and or animation the object is still visible. Does anyone know what to do or fix this problem?
Thank you
Hello
This problem is a known problem. On this link you will find the forum topic
http://forums.autodesk.com/t5/inventor-forum/inventor-2016-studio-fade-animation-not-work/td-p/55930...
regards
Ewoud
dmorris
May not be the same issue.  I recently ran across a fade error (2017 pro) that would not go away until I re-textured the part from "smooth, ivory" to "smooth, yellow," saved the part, and then re-textured back to "smooth. ivory."  Fading (mostly) worked again.  No idea what triggered the bug, but if anyone can benefit from my banging my head against the wall all morning, that would be good!
