Face orientation issues
mgeurts
mgeurts
I'm trying to make a solid out of a .STL.
I repaired some issues in the Repair environment but some remains:
Increasing the tolerance resulted in the same message. Does someone know which different method is meant in this message?
Also, when I click on the Intersecting Faces message, Inventor lags for at least an hour, with CPU usage of not even 5% (then I interrupt)
I also tried the file in 3DSMax and Fusion but due to lack of experience it didn't bring me further.
Does someone has a suggestion on how to continue in order to get an workable solid?
I'm on Inventor 2021
Inventor Professional 2021
3DS Max 2022
Win 10
Gabriel_Watson
Try using Fusion to make this conversion. Inventor is simply incapable of fixing these many issues in a large mesh object:
JDMather
@mgeurts
I see some illogical interference between the muffler and bottom.
Can you ask the source for logical geometry?
The brake rotors do not have any thickness - that isn't logical?
Gaps around the hood, the doors, front headlights?
