Face Draft default values and options
ReneRepina
ReneRepina
Hello!
Is there any possibility to save Face Draft default values and options? We would like to have 45° instead of 2,5° (current default) and second option instead of first option.
We are using Inventor 2020.5.
Best regards,
Rene Repina
Gabriel_Watson
In the registry (for 2022, but to search for other Inventor versions you just need to change the "26.0" with lower numbers):
Computer\HKEY_CURRENT_USER\SOFTWARE\Autodesk\Inventor\RegistryVersion26.0\System\Preferences\Most Recently Used Values\Face Draft\Taper Angle
Value "MRU1" should be the angle you see there.
I am guessing you could switch the "Default" or create another string (MRU2? I don't know) for the draft option to be selected as second, but that would be a question to the devs (if it is indeed possible to do it there like I know the angle is).
ReneRepina
Hi @Gabriel_Watson !
Thanks for the suggestion. I tried it, but it does not work. It does not show the entered value, it gets reversed to default in Regedit and MRU* values are getting reordered for some reason when I change values.
