Extruding issues
Extruding issues
jatNGV77
Observer Observer
Extruding issues
jatNGV77
Observer
Observer
I have derived an Iphone from a rectangle. I now wish to make an Iphone case. I can't extrude sections for volume buttons, charging ports etc. as it only gives me the option to create a 'new solid'. A few students in my class are having the same issue, but not all. Please help!!  Attached is my file.
RobSinglehurst
When you Delete the faces use the "Select Lump or Void" option in the dialog box, this will then leave the part as a solid so your extrusion cuts will then work.
Cheers,
--Rob
Inventor 2024.2
jatNGV77
Observer
Observer
Perfect!! you solved my problem.
Thanks so much!
Jayden
