Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Extruding from one sketch to another one
Message 1 of 11
I would like to extrude from one sketch to another one which is a scaled version of the first sketch. I cannot find an option to do this task automatically.
Replies (10)
Message 2 of 11
YannickEnrico
Take a look at "Loft"
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Message 3 of 11
I tried to do it with loft but it doesn't accept the sketch as a section. When is in this format, all the options of loft are inactive.
Message 4 of 11
YannickEnrico
Can you attach the part?
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 5 of 11
I don't know why it doesn't let me to attach .ipt file. I had to zip it.
Message 6 of 11
YannickEnrico
See this workflow.
It's true that Loft won't allow you to make it in one feature. You can not do "enclosed features" within enclosed features.
So first you make the pyramid - And then you make one of the holes - And then you pattern it around.
@Xun.Zhang- Is it intentional that you cannot attach .ipt files anymore?
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 7 of 11
Thank you for your reply. However, the initial problem I was trying to solve consists of more holes and in the pyramid the holes are not identical. that's why I was trying to do it all at once.
Edited by Request
Discussion_Admin
Message 8 of 11
YannickEnrico
Oh. Unfortunately, that means you'll have to do five lofts. One of the main feature, and one of each hole.
From the programming side, I understand why it works like that.
If you could make all four holes in one feature, you would need a way to define which sketch "goes to" which sketch.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 9 of 11
JDMather
I suspect that your problem is even more difficult.
If you did a loft from any one of those circles to corresponding circle the result will not be circular profile.
Therefore if circular profile is the design intent (I am thinking tubes) you will need sacrificial cylinders to control end tangency and/or guide curves.
I did a problem like this years ago.  It is not impossible, but it is a bit tedious.
Message 10 of 11
johnsonshiue
Hi! Loft creates under-defined geometry (cannot be dimensioned). It should not be a primary tool for mechanical design. It is powerful for sure but it should not be the first tool to use.
For this particular case, I can easily create the precise geometry using one Guide Rail Sweep (see attached part). The forum for whatever reason blocks posting ipt, iam, idw attachment. They need to be zipped before they can be attached. The forum team is aware of the issue and they are working closely with the vendor to address the problem.
Many thanks!
Software Test Engineer
Message 11 of 11
Xun.Zhang
Sorry for late.
Not sure if blocking ipt file uploading was on purpose or not, will check with community admin to understand more.
Xun
