Extruding Curve Instead of Plane
ryan.westra
ryan.westra
I am trying to extrude the plane inside of a curve that I imported, but it seems to want to extrude the outline of the curve, and I can't get it to extrude the whole plane. I tried projecting geometry to a plane, but the same thing occurred. How can I fix this? Screenshot (8).png
JDMather
@ryan.westra wrote:
How can I fix this?
Attach your file here so that someone can find the gap (using the divide and conquer technique).
ryan.westra
Here is the file, thanks.
blandb
Switch to a solid, then click on the red cross and look at what comes of your sketch. Looks like there is some weird stuff going on in some points. Unless my screen is going bonkers.
Autodesk Certified Professional
JDMather
See Attached...
ryan.westra
Thanks, that worked! I didn't realize it wasn't a closed loop for some reason.
