Extrude taper to hollow a lofted profile
dremanef_edu
Community Visitor
dremanef_edu
Community Visitor
Community Visitor
Hello, i have tried sweep and loft and extrude with taper but i can't quite get around how to hollow this rectangle container. Can someone please help? I have designed two profiles on each Z plane.
This profile between planes is tapered 1.5ยบ
I've also tried sweep with the path between planes but it gives me this: (it taperes the base profile, instead of finding the other rectangle:
Thanks for your time!
CGBenner
@dremanef_edu
Welcome to the forum!  Thank you for the images.  Do you have an image of what the final object should look like?  Are you able to share your file here for others to look at?  And last but not least, what version of Inventor are you working with?
Chris Benner
Industry Community Manager โ€“ Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
blandb
Have you looked into shell..
Autodesk Certified Professional
ldutkaTUZ58
Perhaps "Shell", then "Draft"??
CGBenner
@dremanef_edu Hello, do you still need help with this question?
Chris Benner
