Extrude cut,intersect and some functions are not working
This widget could not be displayed.
In my Autodesk Inventor  2019, while I am going for extrude section some of its functions not working
please, someone, help me with that
johnsonshiue
Hi! I believe it means there is no solid body in the part when you start the command. As a result, only Create a Solid option is available.
Many thanks!
Software Test Engineer
These options become available when there's something to cut from or to intersect with.
Once you draw, let's say, a circle or a square onto any of the surfaces of a solid that you have extruded earlier, you'll notice that these options pop up.
