Extreme placement of points when making sketches.
Hello! i´m making a car, and had wished to have a 2d sketch as a mold while i used freeform. But, my sketch is unecessarily huge, and it really messes me up when i try to switch perspectives (home, right top etc.) is there any way to delete these points?
I´ve marked these points with red.
In the yellow ring you can see how small my car sketch is, and how extremely far away that annoying point is.
j.palmeL29YX
I guess (hard to say without of the ipt file) these are center points of arcs with a very large radius.
I don't know a way how you could avoid this "zoom out" while changing the view. 😞 sorry
Theoretical you could activate the "Lock to current selection" (RMB at viewcube) and before changing the view direction select some objects of your model, but not such arcs with large radius. However I think this is not practicable, but you can give it a try.
Jürgen Palme
lol, they are indeed center points of arcs. I used the screen shot tool which made the photos look awful. I ended up making the sketch an image, then pasting it in a sketch once again. But thanks for the help!
