Extents from .ipt part without rule
M_Tuma
M_Tuma
Is possible get flat extent dimensions from part without rule inside .ipt?
I am looking for rule inside .idw, which can get these informations. Code below works fine with parameters, but flat extents are not in parameters.
I didnt use default method (<FLAT PATTERN LENGTH>), because I need this dimensions rounded up with increment.
Thanks for advice
VyhoziModel = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName) ' Get first input model name
Rozvin_delka = Parameter(VyhoziModel+".SheetMetal.FlatExtentsLength") ' HERE I NEED GET EXTENTS LENGTH
Rozvin_sirka = Parameter(VyhoziModel+".SheetMetal.FlatExtentsWidth") ' HERE I NEED GET EXTENTS WIDTH
inc = 0.1 ' rounding increment ( .125, .25, .5, etc)
iProperties.Value("Custom", "ROZVIN")=
Ceil(Round(Rozvin_delka,4) / inc) * inc & " x " & Ceil(Round(Rozvin_sirka,4) / inc) * inc ' IDW iProperties
Curtis_Waguespack
Hi Martin Tůma,
Firstly, it looks like your product license number is set as your forum "handle", it might be a good idea to edit that, so that your number isn't exposed to the world.
But for your question, I think we must use the API for this, as the ilogic calls do not provide a way to access the sheet metal extents from the drawing. See the example below.
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
'get model document
Dim oDoc as PartDocument
oDoc = ThisDrawing.ModelDocument
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
'open a view of the model document
Dim openedView As Inventor.View = Nothing
If oDoc IsNot ThisApplication.ActiveDocument Then
	openedView = oDoc.Views.Add()
	oDoc.Activate()
'unfold to make sure the flat pattern exists
oCompDef.Unfold
'get length
Rozvin_delka = oCompDef.FlatPattern.Length
'get width
Rozvin_sirka = oCompDef.FlatPattern.Width
'close model
If openedView IsNot Nothing Then
	openedView.Close()
'round values
Rozvin_delka = Ceil(Round(Rozvin_delka,4) / inc) * inc
Rozvin_sirka = Ceil(Round(Rozvin_sirka,4) / inc) * inc
'set IDW iProperty
iProperties.Value("Custom", "ROZVIN") =
Rozvin_delka & " x " & Rozvin_sirka
'display result
MessageBox.Show(iProperties.Value("Custom", "ROZVIN") , "iLogic")
mcgyvr
and you can always just push the extents to custom iprops in the part file then access them in the drawing..
yes the rule to do that is in the ipt.. but so what..
M_Tuma
Thanks, it works well.
