extend
extend
extend
How do i extend both sides by 25mm. I used the extend/shorten feature but it extends the metal longways by 25mm. I need the sides extended by 25mm. How is this done?
Files are INV2013
Regards
IJC
mdavis22569
Couple of ways ....
or you could add a sketch to the sides and extrude them ...
I'm sure others will share ways too.
Mike Davis
blair
You could use the Direct Edit method as well.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
WHolzwarth
Here's a version with updated iProperties and filename. New 2013 dataset attached.
Most is ok, but be aware, that editing with frame generator is not possible, because there's no shape 200x25 included.
Walter
Walter Holzwarth
