Exporting Robot Model to BXD:Synthesis
I am a FRC Team Mentor assessing the usefulness of the BXD:Synthesis simulation software to train our drivers while a competition robot is in the design phase. I am encountering two problems while attempting to export a robot model from Inventor 2018 to BXD:Synthesis.
  1. After importing our robot CAD model developed using CATIA V5, I managed to joint the robot's 4 wheels and the joints showed up in the model browser, as shown in the screen capture below. When I try to export the Robot to BXD:Synthesis, however, the joint nodes do not appear in the Guided Export pane in which we are expected to associate the nodes to their Synthesis equivalent;
  2. When I attempt to do an export with either the One-click or the Advanced export functions, I end-up with only one assembly of the entire robot (which consists of 6 assemblies in the CATIA and imported Inventor models).
I have made attempts to import a variety of robots created in Inventor, Fusion 360, CATIA or published in STEP format and I keep getting the same results.
Is there a specific model Assemblies structure which the Inventor Robot Exporter and BXD:Synthesis need in order to work properly?
Do joints/nodes for the wheel have to appear at the higher-level assembly to be picked up by the Robot Exporter?
Also, I tried to find a Tutorial on the preparation of a robot CAD model, beyond the jointing process, for export and use in BXD:Synthesis, to no avail.
Xun.Zhang
It sounds like a problem for Robot exporter rather than general exporting. The Robot exporter addin should know Joints as well as components via Inventor API.
Please contact the service provider from Robot exporter to get more information.
Hope it helps!
Xun
