Using the code from the below website with a few minimal changes I am getting an error message when I try to run the iLogic rule:
My Code:
path_and_name = ThisDoc.PathAndFileName(False) 'without extension
'Define oDoc
oDoc = ThisDoc.Document
'Specify the drawing sheet
oSheet = oDoc.Sheets("Sheet:1") 'Sheet by name
'oSheet = oDoc.Sheet(1) 'First Sheet
'Say There is a Partslist on the Sheet
oPartslist = oSheet.PartsLists(1)
'Create a new NameValueMap Object
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'Specify an existing template file
'To use For Formatting Colors, Fonts, etc
oOptions.Value("Template") = "I:\INVENTOR\BOM TEMPLATE.xls"
'Specify the columns to export
oOptions.Value("ExportedColumns") = "DET. #; QTY.; DESCRIPTION; MATERIAL/VENDOR; PART NUMBER"
'Specify the start cell
oOptions.Value("StartingCell") = "A6"
'Specify the XLS Table Name
oOptions.Value("TableName") = "BOMs"
'Choose to autofit the column width in the xls file
oOptions.Value("AutoFitColumnWidth") = True
'Export the partslist to Excel with options
oPartslist.Export(path_and_name & ".xls", PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
'------End of iLogic------
Error Message
Error in rule: Export BOM, in document: 6998-AU-3000The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
More Info:
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at LmiRuleScript.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Never mind I figured out the issue
I have the same problem. How did you fixed it? Or do you make new iLogic code?
Instead of all that, just go to BOM in your .iam (assembly)
On the Assemble tab select Bill of Materials, go to parts only, (right click and enable BOM view), then click on done,
and create a snippet, the snippet is the one at the bottom, run it and then go where you have your file .iam saved, and the excel file with the BOM exported is called "fileName" (thats the name of the file actually!)
the Snipet:
ThisBOM.Export("Parts Only", "fileName", kMicrosoftExcelFormat)
Cheers!!
