Exporting multiple dwg with sheet number included
Kramarcik
Message 1 of 9
Kramarcik
I think this should be something easy but i cant find a way to do it. I want a single idw per project and include all the drawings inside this idw. I rename each sheet so that I can orient myself. After drawings are finished I usually save a copy as dwg for autocad which I sent to be manufactured. BUT as I renamed all the sheets, when they are exported as individual dwg files, they are not in order anymore, they are orded alphabeticaly. Inventor keep track of sheet number, can it generate the sheet number in the name of dwg file?
order of sheets in idworder of sheets in idw
Here is an order of drawing in idw, but when I batch generate individual files this info is lost, I used to manually rename the files to start with sheet number, but this is very time consuming.
Any help?
Replies (8)
Message 2 of 9
blandb
Here is a rule I found online that I use. You will need to adjust to your liking. But it will combine all sheets of my drawing into a single pdf file. You can choose how and when to run this rule.
Dim doc = ThisDoc.Document
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
filePath = ThisDoc.Path
oDataMedium.FileName = filePath + "\" + iProperties.Value("Project", "Part Number")+" - REV " + iProperties.Value("Project", "Revision Number")+".pdf"
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("Remove_Line_Weights") = 1
'oOptions.Value("Vector_Resolution") = 4800
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
MessageBox.Show("PDF CREATED!", "PDF PRINT")
Autodesk Certified Professional
Message 3 of 9
Kramarcik
does not work. Sorry I am very elementrary in ilogic, cannot troubleshoot yet
Message 4 of 9
blandb
Did you create a rule in the drawing? Can you post what the problem is?
Message 5 of 9
Kramarcik
I ran it one more time, on different idw and it worked, but:
the rule creates a singly .pdf file named "part name" - Rev A
What I want is to create individual .dwg files named like this:
"sheet number on idw" - "sheet name" or "part name".
I guess this can be achieved through ilogic only. Any help is appreciated 🙂
Message 6 of 9
A.Acheson
Here is a ilogic rule to sort browser nodes(sheets) . The sorting is done by sorting the list. This will likely sort alphabetically but you will need to read your page number. You should be able to modify the rule to rename and sort. You can have the post moved to the customization forum where you can get some help working through that. I have seen a rule thst renames and sorts but it is eluding me this morning.
Regards
Alan
Message 7 of 9
Kramarcik
I am an ilogic beginner so tough luck for me, but at least i know it can be done 🙂
Message 8 of 9
blandb
My apologies, I missed the dwg part. I just did a file export to DWG, and here is what I got:
This is my IDW:
Then in windows explorer it spit out:
It kept the original drawing name, because when prompted for a file name, whatever is typed in the box is what is placed in front of the new sheets as shown above. If I would of placed "-" I would of gotten:
But it is keeping the renamed sheets from the idw.
Message 9 of 9
Kramarcik
It does keep the names, but look at the order in your folder
I want to add the sheet number to the dwg (preferably not manually) to keep the same order of drawings as is in the idw.
