Inventor Forum
Exporting Inventor Assembly to RVT
2 REPLIES 2
JoelMckone
459 Views, 2 Replies
An architect has requested Revit files for several window configurations from the Inventor Assembly files.  Management has no issue with providing them as the export to RVT is a simple procedure.  The one condition from management is that none of the iProperty or custom iProperty  vendor information be included in the files.  Since I do not have any experience with Revit, how do I ensure that is information is excluded during the export process.  Is there a file viewer for Revit that would enable me to confirm that the file is essentially the image only and where would I find this information if it did exist?
Although I expect that suppressing this information is done during the export process, would this question be better suited to the Revit community?
2 REPLIES 2
Gabriel_Watson
in reply to: JoelMckone
When authoring the building properties, verify this is NOT on if you wish to omit custom iProperties from being exported:
Then throw a mock/sample file already exported to RVT format into the Autodesk Viewer, and select Properties to find out what passed through:
https://viewer.autodesk.com/
JoelMckone
in reply to: Gabriel_Watson
Thanks for the reply - exactly what I needed to know.
