Exporting Inventor 2020 Assembly to STEP positions the origin of the STEP part in a different place to the origin of the original Inventor part
qamar.naseem6EVRX
Message 1 of 14
qamar.naseem6EVRX
Exporting Inventor 2020 Assembly to STEP positions the origin of the STEP part in a different place to the origin of the original Inventor part. This is a random
Replies (13)
Message 2 of 14
JDMather
Can you Attach files here that exhibit this behavior?
Message 3 of 14
qamar.naseem6EVRX
HI JD, Please find assemblies as requested
Message 4 of 14
qamar.naseem
Hi JD, I dont know whether you got the files before, but they are attached below again.
Message 5 of 14
JDMather
An Inventor assembly must have parts.
In Inventor - parts in in the format of *.ipt files.
You also have 4 subassemblies.  Of course, the subassemblies are needed to in order to make a diagnosis of the issue.
Message 6 of 14
qamar.naseem6EVRX
i dont think i can attach a pack & go zip?
Message 7 of 14
qamar.naseem6EVRX
Apologies JD, Here is the pack&go with the assemblies
Message 8 of 14
JDMather
When I open your Inventor Files and STEP files the Origin and XYZ are identical.
Can you show image of difference that you see?
Message 9 of 14
qamar.naseem6EVRX
Hi JD,
The attached video shows the initial assembly showing the relevant origins in their CORRECT positions in the assembly.
When the STEP file is created, if you look at the video, the origins of the 150x100x10 profile move to the assembly origin.
Message 10 of 14
johnsonshiue
Hi! I don't think this particular workflow is supported. When a non-Master PosRep is active, the position overrides are applied. At that point, file save is not allowed. As a result, export is blocked. Here is a simple workaround. Place the assembly with the non-Master PosRep active in another assembly. Then export the new assembly to STEP.
Many thanks!
Software Test Engineer
Message 11 of 14
qamar.naseem6EVRX
There is NO positional rep created for any part or in the assembly, so I am unsure what you mean.
Message 12 of 14
johnsonshiue
Hi Qamar,
I am sorry for multi-threading errors. I was thinking about a different issue. I took a closer look. I can confirm the behavior. The origins in individual parts are not the same as in the source ipt files. This does not seem right to me. I need to work with the project team to understand it better.
Many thanks!
Message 13 of 14
johnsonshiue
Hi Qamar,
This has been confirmed as a defect (ATF-15539).
Many thanks!
Message 14 of 14
qamar.naseem
Yes Thanks, This has already been passed to developers
