Exporting flat-pattern view in Drawing as .dwg.
Hello! I am trying to find a work-around to a multi-step procedure in order to save time and
increase accuracy. I would like to export the flat-pattern view of a part in a drawing as a .dwg file, in the same way I would as the "Export face...." command in the sheet metal environment. Right now, I must open the part from the flat pattern view, flatten the part, then right-click the face I would like to export as a .dwg file. This is very time-consuming and the flat pattern drawing view looks the same as the flat pattern in the sheet metal environment (when correctly oriented). When I attempt to export the selected flat pattern drawing view on a sheet (highlighted view), the export always includes the entire sheet or sheet. How can I export only the highlighted flat pattern view. Many times the flat pattern view on the drawing is not the same represented side as the model flat pattern side at my workplace, which forces me to compare the drawing flat pattern representation to the exported face in the model. By exporting directly from the drawing sheet, I could save several steps for every part, as well as guarantee the the orientation on the sheet is identical to what is exported for shop use. Thanks so much for your time and any response. Dave
