Inventor Forum
Exporting all bodys in an .ipt as stl's
3 REPLIES 3
marco_vorbuschMJ3EH
255 Views, 3 Replies
Hey there
Often times I draw smaller "assemblys" of 2-8 parts in a single .ipt file with seperated bodies. With this low number of bodys its sometimes just easier to create it like that. When I want to export these bodies to seperate .stl files I have to hide all bodies but one, export as stl and then repeat for every body. Is there a way to make this process less time intensive?
Tags (3)
Labels (1)
3 REPLIES 3
Shift + RMB -> body priority
RMB -> hide others
Eksport
RMB -> all visibility
Repeating the cycle
Alternatively:
Derive out the bodies to the parts in assembly
Eksport to STL -> Options -> Structure -> Multiple files
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Hi!
You can turn the multisolid into an assembly and get the solids separated as independent part files.
CCarreiras
Yes option 2 definetely helps. I usually did it via hiding all other bodies but that workflow annoyed me so deriving an assembly and exporting from there is okay. Thanks.
