Export to Single-Layer DXF
vindashtri
Message 1 of 8
vindashtri
Another software I use requires single-layer dxf files, and when I try to export (using save copy as), I get a dxf with no features. How can I get a single-layer dxf out of Inventor. I have AutoCAD as well if I need it or its tools.
Replies (7)
Message 2 of 8
kacper.suchomski
Try this:
Select a surface in the model, right click, select Export surface.
You can do it in a flat pattern or in a model.
Kacper Suchomski
Message 3 of 8
vindashtri
I should've clarified. I'm not working with a 3-D model, but rather a dxf that seems to be behaving abnormally. My goal is to flatten the dxf without losing features. I have attached the file.
Message 4 of 8
kacper.suchomski
What do you do with this file in Inventor? Describe your workflow.
Kacper Suchomski
Message 5 of 8
vindashtri
This is a dxf output from another software, and I was hoping I could use inventor to flatten it. I'm working on a solution with AutoCAD that I think can work consistently. I appreciate the help
Message 6 of 8
kacper.suchomski
This geometry is flat; or does not show all the information.
Kacper Suchomski
Message 7 of 8
Frederick_Law
Yeap, it is single layer flat dxf.  With some locked dimensions.
Message 8 of 8
Frederick_Law
In AutoCAD, select everything then enter command:
chprop la 0
"Change Property Layer 0"
You can make custom command with that.  Probably can add select all to it:
_ai_selall chprop la 0
