when I export iam file to DWG, Top view from the iam file become Front view in dwg file.
I been fixing it with changing view setting in Autocad.
is there way to either make iam match dwg orientation or make dwg match iam view orientation?
Solved by johnsonshiue. Go to Solution.
Hi! You could redefine the ViewCube orientation (Top, Front, and Home) in the iam and ipt files. You can also make the change in the template files.
Many thanks!
I was hoping there are different way than changing orientation in the AutoCAD...
Thanks for Help!
