Export PDF Defaults
Export PDF Defaults
graeme_robinson
Message 1 of 10
Export PDF Defaults
graeme_robinson
Morning
Using Inventor 2014 and Inventor 2015, every time I export a PDF file I have to select all sheets and change the DPI to 1200
Is there a way to set this as default.....can see any reason whay anyone would want to PDF only one sheet of a drawing as default?
becomea a bit of a bottleneck when PDF'ing lots of drawings
Thanks hopefully
G
Replies (9)
Message 2 of 10
mdavis22569
We have a print settings set up for this vs exporting.
However there is a post about setting up standards and Ilogic in Inventor that you might find useful, or at least start leading you down the path your looking for
https://forums.autodesk.com/t5/inventor-general-discussion/pdf-export-settings/td-p/3815938
Mike
Mike Davis
Message 3 of 10
Mark.Lancaster
Also check out the Autodesk Inventor Exchange app store.  There's a couple of apps out there that allows the user to create print settings like AutoCAD and then store them as icons/buttons on the Inventor ribbon.
Mark Lancaster
Message 4 of 10
graeme_robinson
iLogic looks good but these are not my files so I cannot add iLogic to them
Thanks again
G
Message 5 of 10
mdavis22569
Why? You wouldn't be modifying the file in any way.
If not you could do it the printing way and set up your standards there.
Mike Davis
Message 6 of 10
graeme_robinson
Im not that familiar with Ilogic, all the other iLogic I have seen have been embedded in the file?
If the ilogic can just sit local on my machine and not affect the various customers files then that would be brilliant
Main customers use their PDM systems to generate PDF files which sadly I dont have access to as I work offline from PDM
Cheers
G
Message 7 of 10
mdavis22569
I'm sure you can set up a trigger on your machine, it doesn't have to save the IDW...but rather export rule for Ilogic.
i'll be honest I'm great at Ilogic, however @Curtis_Waguespack might be able to help.    Also check out the customization forum.
I have Ilogic rules I use at work, but when I'm at home they aren't there.   You can store them locally on your pc. You'd just bring up the browser for Ilogic.
Mike Davis
Message 8 of 10
graeme_robinson
G
Message 9 of 10
graeme_robinson
Job done
Downloaded
SmartInventor Easy Export
from the exchange apps
Much appreciated
G
Message 10 of 10
Paul-Mason
Try this little IV add-on. Once installed and setup you can place an export to PDF icon on any of you menus, you set it up to the resolution required, there is also an option to export all sheets in one go.
Tor run remove .jpg from the end
Inventor 2026 Pro
HP Z4 G4 workstation
Xeon
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
