Export Multiple Sheets To Separate PDF's
Message 1 of 15
Morning all!
Just wondering if there is a way to export each sheet within a drawing to its own PDF?
I have created 5 drawings, each with multiple sheets and I want to export them all as separate PDF's due to separate manufacturing processes needed.. Rather than sending them the entire drawing I would like to only send the relevant sheets of the drawing to them,
Is this possible or would I need to create an entire separate drawing for these sheets?
Many thanks and happy Monday!
Dylan
UPDATE:
I have been able to export each sheet to its own PDF but have had to save them all one by one, surely there is a way to make this a little quicker?
Replies (14)
Message 2 of 15
mdavis22569
hi @Anonymous
Not sure of a way out of the box. BUT ..... iLogic might be possible.   The issue is getting it to stop.  Might need to put in the number of known sheets ....
Mike Davis
Message 3 of 15
philip1009
This can be achieved with iLogic.  Could you provide a sample of what you you'd like to name each PDF and where to save it?  When you export the PDF, what options do you use?
Message 4 of 15
Hi Phillip,
I use very similar formats across many different projects, for example,
CARN001-Bracket (would be a sub-assembly of a larger assembly)
Therefor within the CARN001-Bracket drawing would be multiple sheets with titles such as, CARN001-01-Bracket top, CARN001-02-Bracket Bottom, CARN001-03-Bracket Pin...
Im after saving them all as separate PDFs with names in a very similar format as the example above,
At the moment, I am opening the drawing with multiple sheets within, and manually exporting each sheet as its own PDF, which works but can take quite a long time if there are lots of parts and sub assemblies
Message 5 of 15
Cadmanto
Dylan,
Maybe iLogic can expedite this quicker, and not sure if below is what you are talking about in your update, but you can print to pdf and just select the sheets you want or one at a time.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 6 of 15
philip1009
So you want to export pdf drawings of each part and assembly from a top level assembly, and each sheet would have it's own PDF?
Here's a sample loop that goes through each occurrence in the top level assembly and then goes into a secondary loop for each sheet in each drawing.  The name for each sheet is pulled from the name of the sheet in the browser, you just have to make sure each sheet name is unique otherwise it will overwrite other pdf sheets.  And all of the PDFs will be saved in the same folder as the top level assembly.  Let me know how this works for you:
SyntaxEditor Code Snippet
'['Sub Variables
oRefDocs = ThisApplication.ActiveDocument.AllReferencedDocuments
Dim oDoc As Document
oFolder = ThisDoc.Path
oAddIns = ThisApplication.ApplicationAddIns
oTG = ThisApplication.TransientObjects']
'['PDF Export '['PDF Options PDFAddIn = oAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = oTG.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = oTG.CreateNameValueMap oDataMedium = oTG.CreateDataMedium oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 4800 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet'] For Each oDoc In oRefDocs idwPathName = Left(oDoc.FullDocumentName, Len(oDoc.FullDocumentName) -3) & "idw" If System.IO.File.Exists(idwPathName) Then oDrawDoc = ThisApplication.Documents.Open(idwPathName, True) For Each oSheet As Sheet In oDrawDoc.Sheets oSheet.Activate oDataMedium.FileName = oFolder + oSheet.Name + ".pdf" Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium) Next oDrawDoc.Close(True) End If Next'] MessageBox.Show("PDF Export completed.", "PDF Export", MessageBoxButtons.OK, MessageBoxIcon.Information, MessageBoxDefaultButton.Button1)
Message 7 of 15
Thanks Cadmanto,
I will have a look into iLogic and see if I can work something out using that,
The PDF's that I am creating are for the use of manufacturers, mainly so I can email certain parts to different manufacturers rather than sending them everything and confusing things,
At the moment I can use the singular save method and whatever iLogic will help with but I am trying to streamline the process as I am pretty new to the whole thing and want to make my life easier where possible Smiley Very Happy
Message 8 of 15
That is exactly what I am after!
To be honest though this is slightly out of my league, I looked at this and became instantly confused haha,
I think I understand what it means but would I need to input something like this myself? if so where would I find this kind of feature?
Message 9 of 15
philip1009
This is through a feature called iLogic.  On your Ribbon, go to Manage>iLogic>iLogic Browser, this brings up a browser pane that you can drag around or snap just like your Model browser.  In the iLogic Browser, go under the Rules tab, right click in the open space and click Add Rule.  Name this rule whatever you want and click OK.  Then paste the code into the space.  The code used in iLogic is called Visual Basic if you'd like to learn more about it.  After the code is in there, click save then close the rule.  Whenever you want to run the rule, right-click on it and click Run Rule.  Like I said before, this code is designed to run from an assembly document with no other Inventor documents open.
EDIT:  I missed a couple of lines in my previous post, here's the updated code:
'['Sub Variables
'['PDF Export
'['PDF Options
			oSheet.Activate
		Next
	End If
Next']
 EDIT:  If you'd like to learn or ask more about iLogic code, the Inventor Customization forum is a better place than the regular forum.
Message 10 of 15
Ahh thats brilliant thank you for explaining it in terms I understand Smiley LOL
I will definitely look into the iLogic rules then over the next few days and try to wrap my head around it, is it a feature you would recommend and is it a useful addition to everyday use of inventor?
Message 11 of 15
philip1009
Basically, as you know, every company does their drafting and workflows differently.  Autodesk does it's best to cover all of the basic and general functionality and does more to cover more popular options, but it's impossible to make software that works for everyone specifically, that's where iLogic comes in.  To be clear, iLogic doesn't add or unlock any functionality that Inventor doesn't already have, it's just a tool of automating tasks, I definitely recommend learning it as it can be very powerful depending on your workflow.  On average I find automating design shortcuts or pushing mundane tasks to automation can decrease user time to about a 3rd of what it was before.  To learn more about coding in Inventor, click the drop down in the upper right corner of Inventor next to the help button, hover over the Help, and then in the pop-out from there is the Programming/API Help, just keep in mind that not all of that code can be used in iLogic as it has limitations.
Message 12 of 15
peter.roman
How would you do this to only export the sheets of the active drawing / drawing with the rule (not all drawings of referenced drawings)?
I can't seem to get it to work
Message 13 of 15
Dear Sir
Thank you very much for code. I tried to implement it, but all drawings has no 0 kb mass. Additionally there are no pdf extension. When I added .pdf extension manually then files cannot be opened as well. Do you have any idea what is can be wrong?
Best regards
Greg
Message 14 of 15
nurinadlina695
Community Visitor
Community Visitor
I followed your steps but it seems I still can't get to export the drawing sheet to pdf separately. Please help. Thank you.
Message 15 of 15
WCrihfield
Hi @nurinadlina695.  I am not sure what all of your unique needs may be in this case, but give the following iLogic rule a try.  I tried to include lots of 'comments' within the code, to help guide you through what each line of code is trying to do.  If you have any questions, or it is not working as planned, just let us know.
Sub Main
	'get the current document, then try to Cast its Type to the DrawingDocument Type
	'if that fails, it will not throw an error, but will not set a value to the variable
	Dim oDDoc As Inventor.DrawingDocument = TryCast(ThisDoc.Document, Inventor.DrawingDocument)
	'if the variable did not get a value, then exit rule
	If oDDoc Is Nothing Then Return
	'get the PDF Translator Add-in
	Dim oPDFAddin As Inventor.TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById( _
	'Create the variables needed by the Translator Add-in
	Dim oTO As Inventor.TransientObjects = ThisApplication.TransientObjects
	Dim oContext As Inventor.TranslationContext = oTO.CreateTranslationContext()
	Dim oOptions As Inventor.NameValueMap = oTO.CreateNameValueMap()
	Dim oDataMedium As Inventor.DataMedium = oTO.CreateDataMedium()
	'The following If-Then statement sets the values of available Options.
	If oPDFAddin.HasSaveCopyAsOptions(oDDoc, oContext, oOptions) Then
		oOptions.Value("Publish_All_Sheets") = 0 ' 0 = False, 1 = True
		oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintCurrentSheet
		oOptions.Value("Launch_Viewer") = 0 ' 0 = False, 1 = True
		oOptions.Value("All_Color_AS_Black") = 0 ' 0 = False, 1 = True
		oOptions.Value("Vector_Resolution") = 720 '150, 200, 400, 600, 720, 1200, 2400, 4800 ' DPI
		oOptions.Value("Remove_Line_Weights") = 0 ' 0 = False, 1 = True
	End If
	'get static parts of new file name (not sheet depentant)
	'this gets full path, without file name (does not include "\" character at end)
	Dim sPath As String = System.IO.Path.GetDirectoryName(oDDoc.FullFileName)
	'this gets just the file name, without any path, and without file extension
	Dim sName As String = System.IO.Path.GetFileNameWithoutExtension(oDDoc.FullFileName)
	'this just gets the directory separator character
	Dim cDirChr As Char = System.IO.Path.DirectorySeparatorChar
	'record originally 'active' sheet
	Dim oASheet As Inventor.Sheet = oDDoc.ActiveSheet
	'<<<< Start loop for each sheet - file name includes sheet name >>>>
	For Each oSheet As Inventor.Sheet In oDDoc.Sheets
		'activate this Sheet in the drawing
		oSheet.Activate()
		'extract just the index number of this Sheet
		Dim sSheetNumber As String = oSheet.Name.Split(":")(1) 'get the digit(s) after the ":"
		'same path and file name as drawing, but with .pdf file extension
		Dim sNewFileName As String = sPath & cDirChr & sName & " Sheet " & sSheetNumber & ".pdf"
		'Check to see if this PDF already exists
		If System.IO.File.Exists(sNewFileName) = True Then
			'this file already exists, so ask user if they want to overwrite it
			Dim oAnswer As MsgBoxResult = MsgBox("A PDF file with this name already exists." _
			& vbCrLf & "Do you want to overwrite it with this new one?", _
			vbYesNo + vbQuestion + vbDefaultButton2, "PDF ALREADY EXISTS")
			'if they do not want to overwrite it, then skip this Sheet
			If oAnswer = MsgBoxResult.No Then Continue For
		End If
		'set new PDF full file name
		oDataMedium.FileName = sNewFileName
		'Publish PDF
		oPDFAddin.SaveCopyAs(oDDoc, oContext, oOptions, oDataMedium)
	Next
	oASheet.Activate()
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
