@lodes39 wrote:
... just a simple shape with the same .dxf result:
Before I show the solution - what program are you opening the dxf file in?
When I Open the dxf file that YOU attached in AutoCAD this is what I see...
...if I Explode the polyline and run the List command ...
the geometry is reported as Arcs.
In the video I forgot to mention turning off arc center point layer...
in AutoCAD you could also turn it off after the fact,
but if you are using some other software with the dxf you probably want to turn it off in Inventor before saving the file.
