Does anyone know if it's possible to export a file from Autodesk Inventor to Abaqus (FEM software)?
If so, what is the file format to use when exporting from Inventor?
João
Solved by jtylerbc. Go to Solution.
I've never used Abaqus in particular, but a quick online search turned up the online help for Abaqus, which includes a list of compatible file formats. A skim of that indicates that it can import ACIS (.sat), IGES (.igs / .iges), and STEP (.stp, .step), all of which can be exported from Inventor.
I would probably start with a STEP file, and consider trying the others if that doesn't work.
