Export from inventor to 3ds max with materials - Problem
Hello all.
I need to export an inventor file to 3ds max with four basic matrials.
I Export file to 3ds max
I open the file in 3ds max
But instead of 4 basic materials I have plenty of the same name + name of the part with this material. When I replace the material I have to add each to each part.
I want to quickly replace the material for all parts with the same color (material name). Because sometimes I have models with hundreds of parts.
Please help.
Yong.Jing
Autodesk Support
Autodesk Support
3D Max could import Inventor file directly,  During the import, it has options to check the options about materials?
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Thank you for your answer.
I have already tried importing from 3ds max.
I had the same settings as you but I continue to import material for each material separately for each profile.
Do you have any other ideas?
Why is this happening?
