Export Face As... option not available for this particular part
achintya_bhatnagar
Message 1 of 9
achintya_bhatnagar
I'd like to export the face of this part as a DXF file. When I right click on its face and select that option, in the DXF file it doesn't show the small circles inside the big circles. When I select the face as well as inside circles by pressing Ctrl+click and then right click, the option Export Face As... is no longer available. How can I export this as DXF correctly? (with the inner small circles as well)
When I select the inner circles too, the option Export Face As... option is no longer available:
Thank you for your help!
Replies (8)
Message 2 of 9
Gabriel_Watson
Maybe just create a sketch on the top face, use "Project Cut Edges", exit the sketch, and then right-click it to "Export Sketch As...", picking DXF as the format.
Message 3 of 9
pcrawley
"Export Face As" only exports a single face.  Those "inner circles" are separate faces.
As well as the suggestion above, you can right-click the existing sketch and "Export Sketch As..." DXF:
(The advantage of creating a new sketch on the face is that it won't contain the construction geometry from the original sketch.)
Peter
Message 4 of 9
kacper.suchomski
Select all faces using ctrl or shift.
If you select one face - it will export one face.
Kacper Suchomski
Message 5 of 9
achintya_bhatnagar
That's what I tried in the second screenshot, but when multiple selections are made using control or shift, the Export Face As option doesn't appear.
Message 6 of 9
achintya_bhatnagar
I get too many extra lines in DXF when I do that.
Message 7 of 9
achintya_bhatnagar
I think this can work. I will try this. Thanks.
Message 8 of 9
achintya_bhatnagar
It worked perfectly! Thank you.
Message 9 of 9
kacper.suchomski
Faces or circles?
Edges is not faces.
Kacper Suchomski
